Opening Master in Thingworx 5.4
sgobi
7-Bedrock
Hi
I have a DefaultPageMashup selected on my Master. When I try to open Master it does not open any mashup.
This feature was available in 4 version.
Is there a workaround?
Sabarish
adam11
7-Bedrock
(To:sgobi)
Sabarish,
Are you opening the Master from Composer (i.e. 'View Mashup')? If so, you need to remove the extraneous "&mashup=". After removing this from the URL, your Mashup will load as expected.
Adam
sgobi
7-Bedrock
(To:sgobi)
Thanks Adam. That worked.
Previously, the Link used to include the mashup as well.
Now it is enough only if we give the link removing the &masup to the users.
