Currently we are using responsive containers in thingworx composer design.
When clicked on second dropdown, its options are overlapping with first down
Expectation is to get options just below its own dropdown. Please help us to achieve this.
If you are using DropDown widget, try changing value for ListMaxWidth.
Ensure there is no external CSS getting applied. Alternatively, you can try with List widget if it is the same behavior.
There is no property called ListMaxWidth in Thingworx 9.3 and there is no external CSS present.List widget is not behaving like dropdown widget.Thanks
Okay, I had checked this option in 9.4.6
Hi @krishnakomal211 ,
It appears that there is a reply to answer your question. For the benefit of other Community Members who may have the same question, it would be great if you could designate it as the Accepted Solution.
In the event that this response did not answer your question, please post your current status so that we can continue to support.
Thanks for using the PTC Community!
Charles
I am still waiting for a solution for this. Thanks
Hi @krishnakomal211, it seems that the workaround functionality has been implemented in ThingWorx 9.4.6.
Since the standard support for ThingWorx 9.3.x has ended, you may consider upgrading to the latest support version.
Check the Product Release Calendar for more information on ThingWorx versions.
Hope it helps!
