PAT MQTT
Krathi123
7-Bedrock
PAT MQTT
I have used sample mqtt project for connector.It allows only single property write at a time. Is there any way so that i can do multiple property write in single JSON.
WritePropertiesMessage is not implemented in sample project.You need to implement it.
I was able to resolve it on my own.
abhkumar
(To:Krathi123)
Hi @Krathi123
Thanks for resolving the issue.  Could you please mentioned resolution so that it will benefit others with the same question?
Abhishek
