PMML model is not ready for testing
plpt
8-Gravel
I created a PMML model with R and want to import it into Thingworx.
In the Analytics Manager I created an Analysis model but I can't enable it because it's not ready for testing.
I do I make it ready for testing?
cmorfin
(To:plpt)
Hi @plpt
Thank you for this.
ThingWorx Analytics supports PMML up to version 4.3, this is the reason you cannot use this PMML file.
If you can export your model to pmml 4.3, that should work better.
Kind regards
Christophe
cmorfin
(To:plpt)
@plpt
Could you please confirm what version of:
- ThingWorx Platform
- ThingWorx Analytics Server
- ThingWorx Analytics Extension
you are using .
Also what is the pmml version of the file.
Finally, is it possible for you to upload your pmml file here for testing ?
Christophe
plpt
8-Gravel
(To:cmorfin)
- ThingWorx Platform : 8.5.5
- ThingWorx Analytics Server : 8.5.4-r1
- ThingWorx Analytics Extension : 8.5.4-r1
PMML version is 4.4, I joined the file below
cmorfin
(To:plpt)
Hi @plpt
Thank you for this.
Kind regards
Christophe
plpt
8-Gravel
(To:cmorfin)
Indeed, it's working with v4.3, thank you!
slangley
(To:plpt)
Hi @plpt.
If the previous response allowed you to resolve your issue, please mark it as the Accepted Solution for the benefit of others with the same problem.
Thank you for your participation in our community!
--Sharon
