I try to send a POST command to an API with this code :
var json = {
"machinecode": "E5",
"dispatchtypecode": "PANNE",
"description": "Temps de vide trop long > Chambre Droite",
"tradecode": "Maintenance"
var url1 = "https://xxx.com/api/1.0/dispatches/open/?auth=abcdefghij&site=50";
var params = {
headers: header /* JSON */,
url: url1 /* STRING */,
content: json /* JSON */
// result: JSON
var result = Resources["ContentLoaderFunctions"].PostJSON(params);
But I receive this return :
{"headers":"","success":false,"error":"Unexpected error in open. If problem persists contact Support."}
Could you help me, please ?
Hello Philippe,
Were you ever able to find a resolution to this issue? If so could you please post a reply so other customers who are having the same issue are also able to resolve this.
I succeeded using PostText .
I posted here : https://community.ptc.com/t5/ThingWorx-Developers/POST-JSON/m-p/639366
