POST JSON
  • December 4, 2019
  • 2392 views
I try to send a POST command to an API with this code :
var json = {
"machinecode": "E5",
"dispatchtypecode": "PANNE",
"description": "Temps de vide trop long > Chambre Droite",
"tradecode": "Maintenance"
var url1 = "https://xxx.com/api/1.0/dispatches/open/?auth=abcdefghij&site=50";
var params = {
headers: header /* JSON */,
url: url1 /* STRING */,
content: json /* JSON */
// result: JSON
var result = Resources["ContentLoaderFunctions"].PostJSON(params);
But I receive this return :
{"headers":"","success":false,"error":"Unexpected error in open. If problem persists contact Support."}
Could you help me, please ?
Welcome to the forums, PRopars!
Do you have the variable "headers" set to anything? Does it need to be?
We often use the free Postman app to troubleshoot API calls. I would give it a whirl and see if you can post from it. https://www.getpostman.com/downloads/
PRopars10-MarbleAuthor
Headers is empty.
It works fine with this topic :
https://community.ptc.com/t5/ThingWorx-Developers/REST-call-how-to-use-x-www-form-urlencoded-authentication/td-p/501905
I think that server no authorize application/json POST
