PTC.CSLM.RS.PostgresJDBCThing not found (JDBC configuration )
jaganprasanth
6-Contributor
According to PTC document for JDBC configuration (PTC.CSLM.RS.PostgresJDBCThing ) Thing should be used, but this Thing (PTC.CSLM.RS.PostgresJDBCThing )is not found my Thingworx . Some one guide me for this issue.
There is no reference of PTC.CSLM.RS.PostgresJDBCThing in Thingworx documentation, only in a Servigistics help center.
The only recommendation is to restart Composer after installing an extension (in your case JDBC)  and before doing any configuration  , in order to see the changes.
Hope it helps,
Raluca Edu
I herewith attached the followed steps in screen shot. Please find the attachment
Are you using Servigistics or what do you need to accomplish? I didn't see such thing name in any Thingworx version, maybe you need to import Servigistics Remote Service first.
Raluca Edu
Hi @jaganprasanth.
Have you found a solution to your problem?  If so, please feel free to post it here and mark it as the Accepted Solution.  If the problem still exists, please provide more information.
--Sharon
