Feb 16, 2022 2:50 PM UTC
PVZ for positioning assembly
we are experimenting with the retrieval of pvz resources from windchill for AR purposes using thingworx Flow. In particular, the "get viewable" routine is capable of getting pvz files except for positioning assemblies. In this case, the pvz file has a 0 KB size. How to build a proper pvz also for this type of structure?
Feb 17, 2022 3:53 AM UTC
Which Rest API was used to get the PVZ file from Windchill to Thingworx?
Take a practical example, we can use ptc-windchill-OData-connector to connect thingworx and windchill. Then we can see below usable APIs which allows to get representations from Windchill to thingworx.
  • PTC.Visualization.GetDynamicStructureRepresentation()
  • PTC.Visualization.GetPVZ(IncludeAnnotations={IncludeAnnotations})
  • getRepresentationInRepresentationsByID
  • getRepresentations
To my understanding "PTC.Visualization.GetDynamicStructureRepresentation()" is used to retrieve positioning assembly representation.
GianVal15-MoonstoneAuthor
Feb 17, 2022 7:54 AM UTC
Thank you for your answer. Anyway, I tried to use the "PTC.Visualization.GetDynamicStructureRepresentation()" into the Execute function of thingworx flow, but it returns this error
Failed to execute service 400 "{\"error\":{\"code\":null,\"message\":\"Found unsupported object for entity type.\"}}"
Mar 15, 2022 6:23 AM UTC
