Hey all,
I am using ThingWorx version 8.5.7.
I want to pass a mashup parameter of my parent mashup to the navigation widget.
I created a mashup parameter in this child mashup that I want to navigate to and connected them.
Now, the issue is that there is no data coming through in the child mashup.
I think this is a bug of TW (https://www.ptc.com/en/support/article/CS328676)
However, I need to find a way around it then...
Can anybody help me with this?
Thanks in advance
Sometimes when it happens, you have to reconfigure the navigation: re-select the mashup, and redo the binding.
It may help
Cyril
Hi @TS_9588135.
The Navigation widget was replaced by the Navigation function which can be found in the lower right corner of the mashup builder. Refer to this page of the Help Center for more information.
If you still have issues, please let us know.
--Sharon
It may help
Cyril
