Passing parameters on double click to open the next Mashup
Newbie
I have a  tree widget on a main mashup and  will like to know how to pass parameters on double click to open/view another mashup using the parameters.
Tlallo
Re: Passing parameters on double click to open the next Mashup
Hello, Tlallano.
I found a somewhat similar question in another post. Does the discussion there help you out?
https://community.thingworx.com/thread/41434
Let us know, please.
-- Craig A.
If you want to pass parameters to a container mashup on the same mashup as Craig said look on that thread. If you want to open a new page or a pop-up look onto Navigation widget.
Thanks Guys, that was close to what I was looking for, but the issue is that my tree widget on the main Mashup is made up of Networks that contains Things and I want on selected thing to open a mashup  on a different page. The mashup navigated to its a generic mashup that displays different entity/things data/info.
Is this possible?
