Any one knows what is type of password encryption in Thingworx?,what level of encryption is used?
Thanks&Regards,
Latha
If you look at the UserManagementSubsystem in Configuration there are some settings for the password encryption.
Thank you for response.
Is the both "PBKDF2WithHmacSHA512" and "AES 128-bit" are same encryption methods?.
In User management, password hashing algorithm is "PBKDF2WithHmacSHA512". In Application platform settings mentioned as AES 128-bit. Also, one of the community response as mentioned that AES 128-bit method.
Thanks&Regards,
Latha
