Im using auto refreshal for Navigation between screens. how can i implement pause functionality(button) in this usecase. and suggestions about timer.
Thanks in advance!!
If you don't want to make the AutoRefresh visible and use a button to stop the auto refresh setting:
1. Button only has pause function: Use the button to trigger a service, the service return a False Boolean result, bind the result to AutoRefresh widget AutoRefresh property
2. Button can control both Pause and Play: make the service return True and False result in turn.
Auto-refresh time interval is also a property input for the widget, you can bind a service with Numeric output to it.
The autoRefresh is a widget, and it has a Toggle Button and a Refresh Now button, if you didn't set it to be invisible, you can pause the refresh by turn the widget off. So what do you expect to do?
In autoRefresh widget(for particular interval ex: 10), I am using a navigation, to navigate to other screen, here i want to use a pause button.how can i do that ? how can i write a service to increase auto refreshal time.
Thanks in Advance.
Thankful for ur valuable suggestion and solution!!
As mentioned --
can u be brief how to make the service return True and False result in turn?
i cant bind a service to time interval(numerical input).
So Do i need to use two buttons for pause and play?
what else can i prefer ?
Suggestion from high to low:
1. Use the original Auto-refresh widget
2. Use Checkbox widget or RadioButton widget if you have them
3. Use 1 button and label Play/Pause or 2 independent Buttons
I set up this high to low on my own preference, but if you have your own design pattern, you can apply your favorites.
