Pause functionality for auto refresheral
Deepu
Im using auto refreshal for Navigation between screens. how can i implement pause functionality(button) in this usecase. and suggestions about timer.
Thanks in advance!!
1 ACCEPTED SOLUTION
zyuan1
18-Opal
(To:Deepu)
If you don't want to make the AutoRefresh visible and use a button to stop the auto refresh setting:
1. Button only has pause function: Use the button to trigger a service, the service return a False Boolean result, bind the result to AutoRefresh widget AutoRefresh property
2. Button can control both Pause and Play: make the service return True and False result in turn.
Auto-refresh time interval is also a property input for the widget, you can bind a service with Numeric output to it.
5 REPLIES 5
zyuan1
18-Opal
(To:Deepu)
The autoRefresh is a widget, and it has a Toggle Button and a Refresh Now button, if you didn't set it to be invisible, you can pause the refresh by turn the widget off. So what do you expect to do?
Deepu
(To:zyuan1)
In  autoRefresh widget(for particular interval ex: 10), I am using a navigation, to navigate to other screen, here i want to use a pause button.how can i do that ? how can i write a service to increase auto refreshal time.
Thanks in Advance.
zyuan1
18-Opal
(To:Deepu)
Deepu
(To:zyuan1)
Thankful for ur valuable suggestion and solution!!
As mentioned --
can u be brief how to make the service return True and False result in turn?
i cant bind a service to time interval(numerical input).
So Do i need to use two buttons for pause and play?
what else can i prefer ?
zyuan1
18-Opal
(To:Deepu)
Suggestion from high to low:
1. Use the original Auto-refresh widget
2. Use Checkbox widget or RadioButton widget if you have them
3. Use 1 button and label Play/Pause or 2 independent Buttons
I set up this high to low on my own preference, but if you have your own design pattern, you can apply your favorites.
