esnigirev
Ok, i will continue previous question. If i have value 1 or 0 and 2 pictures (red and green), they are on my mashup because of Image widget. I would like if value is 1 red picture will be invisible if value is 0 green picture wiil be invisible. How can I do it?
supandey
(To:esnigirev)
Hi Egor, you can consider binding the boolean value to the Visibility property type of the Image widget. As you can see below this will enable you to Enable/Disable the visibility of the Image widget
