Popup widget for Notification
the_incapit
6-Contributor
I need a workaround to display the latest 5 notifications , which I have in an infotable(only a way to visualize the data is required). What I need is a widget / workaround to display the notifications in a small popup in the same mashup and at the end of the notifications I would like to have a button to navigate to another mashup. I have used Mashup as popup and it is navigating to a popup page where the popup comes at the middle. I need it to be in a corner.
To see exactly what I mean I am attaching an image which show the visualization
Kindly suggest any workarounds or widgets which I can use to make it look like the popup in the image.
Thank You
1 ACCEPTED SOLUTION
cmorfin
(To:the_incapit)
Hi @the_incapit
indeed there is some limitation with this.
You could try using % instead of pixel, that should help with different resolution, though that won't fix everything.
.mashup-popup{
left: 82% !important;
top: 10% !important;
Regards
Christophe
4 REPLIES 4
cmorfin
(To:the_incapit)
Hi @the_incapit
It might depends on how you created your popup and which release.
I have done a quick test with a navigation function (not widget) in 8.5 for a modal popup and the position of the popup can be controlled with custom css like:
.mashup-popup{
left: 400px !important;
top: 80px !important;
hope this helps
Christophe
the_incapit
6-Contributor
(To:cmorfin)
Thank you for your reply, but I have a few problems like.
The popup coordinates are hard coded. If I open the view in a different resolution, the alignment breaks.
The popup is not responsive. Doesn’t scale according to view.
Is there any solutions for this , or any entirely different approaches for my question.
cmorfin
(To:the_incapit)
Hi @the_incapit
.mashup-popup{
Regards
Christophe
the_incapit
6-Contributor
(To:cmorfin)
Thank You for your help, helped me solve the problem to a certain extent.
