Post-Intsall Step Error with ThingWorx Trial Edition 8.2 installation
automata
I am getting a post-setup installation error. I have also attached my Log Files and the error screen shot.
I am not really getting what's the problem. My port 8080 is free as i have checked it by checking in the command prompt.  I have installed docker tools and the default container is running fine.
 Please help as i couldn't find the solution to this issue anywhere.
I was having same issue. Solution to solve the problem is as below.
Once you are done with Docker installation. Set it to run in Linux Container instead of windows. Allocate minimum 8 GB RAM to it and then try to install the trial edition. It should get installed.
5 REPLIES 5
visla
(To:automata)
Hello!
By searching in our Knowledge Base (KCS), I have found the following article that might help you:
https://www.ptc.com/en/support/article?n=CS266385
It is also important to make sure you are using the right license file, as I have seen a customer having similar issue when using invalid license file.
In case you don't manage to fix this issue soon enough and you need to get access to a ThingWorx server for general testings, you might want to have a look at the Foundation Server Trial available in ThingWorx Developer Portal:
https://www.ptc.com/en/support/article?n=CS265556
I hope that helps!
Best Regards,
Vanessa
automata
(To:visla)
xxxThanks Vanessa,
I did the Docker setup correctly this time. I am running docker on windows.
Checked the share C drive.
Went on with the installation but it halted again on the below post installation error.
Error running .\installer-twxutilities-devzone-windows.exe
--installdir "C:\Program Files (x86)\ThingWorxTrial Edition
--TWXHOST_HOST "10.075.`" --TWXHOST_PORT "8080"
--TWXHOST_USERNAME "xxxx"
--TWXHOST_PASSWORD "xxxx"
--unattendedmodeeui minimal --mode unattended
--accept_uela YES:  Program ended with an error exit code.
Is there a solution to this problem or what should i do to get this corrected?
automata
(To:automata)
I am getting the error on TWX utilities post-installation.
I have attached the log file and error image.
cmorfin
(To:automata)
Hi
In addition to what Vanessa indicated, it seems that the installation fails because the ThingWorx Foundation container did not start in a timely manner.
You will want therefore to ensure that your machine follows the pre-requisite from https://support.ptc.com/WCMS/files/174119/en/ThingWorxTrialEditionGuide8.2.pdf and that you have increased the default RAM allocated to the docker daemon as indicated in the above guide in the pre-requisite too.
Hope this helps
Chrisotphe
