PostgreSQL Configuration : /thingworx-grants-schema.sql: No such file or directory
mnalla
7-Bedrock
I installed postgreSQL and while doing configuration I got the following error:
Can anyone please help me out..?
Madhu
2 REPLIES 2
supandey
(To:mnalla)
Hi Madhu, wondering did you run the DB setup (with batch file thingworxPostgresDBSetup ) prior to running schema setup ?
mnalla
7-Bedrock
(To:supandey)
yes, I run the DB setup (with batch file thingworxPostgresDBSetup ) prior to this.
regards,
madhu
