Hi
I'm trying to use Expression with 5 inputs but 4th an 5th input is not working. Please help with this issue.
TWX version 9.1.1
I would enter in a bug at support.ptc.com if that is what is happening.
Hi @GAjey.
When you say the 4th and 5th inputs aren't working, what is actually occurring? Can you provide your mashup so we can take a look?
--Sharon
Hi @slangley I have attached the screen shot for the error. When I try to add more than 3 inputs variables and click done it is not saving or take effect in following expression code.
Hi @GAjey
From the screenshot, it appears that you changed the name of the first 3 but not of the last 2. Is it not allowing you to change them?
Also, what do you need for it to do? We're not able to tell much about this since the logic hasn't been provided.
--Sharon
Hi @slangley its simple expression widget I tried and when I try to add more than 3 inputs it does not save. when I click on done button and again open the expression I get to see above that I have sent you in screenshot. That variables does not save
Hi @GAjey.
I recommend we open a case to work through the issue you're seeing. I will be happy to open one on your behalf if you agree.
--Sharon
Hi @GAjey.
From the case notes, it was found that the expression was working as designed. Unfortunately, I don't have the details behind that assertion, so please feel free to elaborate for the benefit of others in the community. Once you have done so, please feel free to mark your follow-up response as the Accepted Solution.
--Sharon
