Problem defining state definition in thingworx 8.4.3
gourinaik98
Hello, I want to create state definition for my shape. but I am only be to define only two types. Please refer the following image. I want to define a style for a range of values. Eg - Green for 1, red for 0 and yellow for  greater than 2
PaiChung
22-Sapphire I
(To:gourinaik98)
If just 0/1 yes String/Value
You only define for either 0 or 1 and the other one will be default
8 REPLIES 8
cmorfin
(To:gourinaik98)
@gourinaik98
If you need to achieve
you can do it by using a String/Value state instead of a Numeric one.
Set the first state to String/Value 1 and the desired style
Set the second state to String/Value 2 and the desired style
Set the default state to the desired style
Hope this helps
Christophe
PaiChung
22-Sapphire I
(To:gourinaik98)
Use the check+ or if you already clicked the check use the Add to add an additional range cut off.
I tried that, it still shows less than or less than equal to only
PaiChung
22-Sapphire I
(To:gourinaik98)
Correct, that is how it is intended.
Your state definitions for number ranges always has to be defined with the approach of
a < b <= c < default
the default state will be anything above the last state you define.
Yeah, so how do we define a?
PaiChung
22-Sapphire I
(To:gourinaik98)
sorry correction you'll see it as
<a - State 1
<=b - State 2
<c - State 3
default
So you define the first cut off and anything below that will be 'state 1' etc.
Okay I've got it. But in my case, the value is 0 or 1. So in that case, as
@cmorfin mentioned, I have to define it as string/value correct?
##- Please type your reply above this line -#
PaiChung
22-Sapphire I
(To:gourinaik98)
