Problem in Thingworx utilities workflow
se1
8-Gravel
8-Gravel
Hi,whenever i launch workflow i get a page with just open tab.New,Save tabs are not being displayed.How to solve this issue?
4 REPLIES 4
anglea
(To:se1)
Check your user permissions.  The user needs to be in the PTC.BusinessProcessAdministrators user group to be able to create and edit workflow definitions in Workflow Builder.
For reference:
http://support.ptc.com/help/thingworx_hc/thingworx_utilities_8_hc/en/#page/ThingWorx_Utilities%2FConverge_PermissionsAndRoles.html%23
se1
8-Gravel
8-Gravel
(To:anglea)
Hi anglea,thank you for response.The permissions are correct but still i am facing the issue :( .
anglea
(To:se1)
Another thing you could check is the 'Visibility Support for ThingWorx Utilities' section in the installation guide:
https://support.ptc.com/WCMS/files/174010/en/TWXUtilitiesInstallGuide.pdf
wq5
6-Contributor
6-Contributor
(To:anglea)
Thank You anglea   :)
