Hello Expert ,
I am getting this error on get yahoo weather :
If you know the solution for this error please suggest me.@
Execution error in service script [WeatherThing GetWeather] : Wrapped org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 429; The content of elements must consist of well-formed character data or markup. Cause: The content of elements must consist of well-formed character data or markup.
Code :
var stringLocation=location+" ";
var arrayLocations=stringLocation.split(",");
var lat=arrayLocations[0];
var long=arrayLocations[1];
//Modify the open weather url here if you are using your own API key
var params = {
url: "http://api.openweathermap.org/data/2.5/forecast?lat="+lat+"&lon="+long+ "&units=imperial" +"&type=accurate&mode=xml&APPID=4abc8a3c9f101ccf9c7cfe7cbf3dfed7" /* STRING */,
timeout: 60 /* NUMBER */
// result: XML
var xmlPage = Resources["ContentLoaderFunctions"].LoadXML(params); // Error Generate on This line
var params = {
infoTableName : "InfoTable",
dataShapeName : "OpenWeatherFeed"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(YahooWeatherFeed)
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var from_today_value=xmlPage.forecast.time[0].@from.substring(0,10);
logger.warn("from_today_value= "+from_today_value);
for each (var item in xmlPage.forecast.time) {
var row = new Object();
var from_current_value=item.@from.substring(0,10);
if(from_current_value!=from_today_value){
row.WindDirection = item.windDirection.@name;
row.WindSpeed=item.windSpeed.@mps;
row.WeatherTemp=parseFloat(item.temperature.@value);
row.WeatherHumidity=parseFloat(item.humidity.@value);
row.From=item.@from;
row.To=item.@to;
row.Title=xmlPage.location.name+" "+xmlPage.location.country;
row.Precipitation=(item.precipitation.@type+" "+item.precipitation.@value)==" "?"No Precipitation":item.precipitation.@type;
result.AddRow(row);
Thanks ,
Mayank
Hi Mayank,
Yahoo Weather API is no longer in service. Please use OpenWeatherMap as a replacement or Wunderground API.
Below is an implementation for a OpenWeatherMap API service call:
var params = {
url: "http://api.openweathermap.org/data/2.5/forecast?lat="+lat+"&lon="+long+"&units=metric&type=accurate&mode=xml&APPID=4abc8a3c9f101ccf9c7cfe7cbf3dfed7" /* STRING */,
timeout: 160 /* NUMBER */
// result: XML
var params = {
row.WeatherTemp=parseInt(item.temperature.@value);
row.From = item.@from;
row.To = item.@to;
row.Precipitation=(item.precipitation.@type+" "+item.precipitation.@value)==" "?"NoPrecipitation":item.precipitation.@type;
result.AddRow(row);
Here are the inputs and outputs of the service
Please let me know if you are in need of anything else.
Thank you,
Veronica
Mayank, you might've already checked this, but just in case - are you getting a valid xml from that url?
Yes Ravi , i got valid xml and Json also , but problem in parsing this xml and as well json in Thingworx service, I tested this online parser and no any error shown me on online parser. Would you provide me any url for weather. so i can test it.
Thanks ,
Hi Mayank,
var params = {
// result: XML
var params = {
row.To = item.@to;
result.AddRow(row);
Thank you,
Veronica
Hi Veronica,
this code is for forecast in weather application, is possible to get code for actual weather in same application? If I am wrong please correct me.
http://openweathermap.org/forecast5 Here you use this, it's for forecast in 3 hours interval
http://openweathermap.org/current
And i would like to get data from this page if it is possible.
So i would like exchange yahoo weather for this one:YahooWeatherFeed.
Thank you for any reply,
Robert
Hi Robert,
Indeed, the code I posted is for retrieving forecast data. You can use the Rest call described in the tutorial link you mentioned.
The parsing of the data once you get it in your thingworx service will be different from the one did for the forecast call. Let me know if you are experiencing problems with parsing it.
Thank you,
Veronica
I am working on parsing of the data but it still doesn't work. If you can help me with that i will be glad.
Thank you,
Robert
Hi Robert,
I would be glad to help. Please post the code your are experiencing trouble with.
Thank you,
Veronica
I have solved it but thank you for your interest.
Robert.
You're welcome Robert. Please don't hesitate to post your questions on the forum if you have trouble with anything else.
Thank you,
Veronica
Thank you,
Veronica
I'm still having an error message of
I guess it's related to this issue
( Mark S. Kolich - Java: Resolving org.xml.sax.SAXParseException: Content is not allowed in prolog )
But I have no idea how to modify the code
Here is the code
var params = {
url: "http://api.openweathermap.org/data/2.5/forecast?lat="+lat+"&lon="+long+"&units=metric&type=accurate&mode=xml&APPID=ff07c7c18d3a5d86f13a93134f1d94a9" /* STRING */,
// result: XML
var params = {
row.To = item.@to;
result.AddRow(row);
Thank you.
Hello Lee ,
Take input parameter as a Location ,
var test=Location+" ";
var arrayLocations=test.split(",");
var prm = {
url : "http://api.openweathermap.org/data/2.5/forecast?lat="+lat+"&lon="+long+"&units=metric&type=accurate&mode=xml&APPID=4abc8a3c9f101ccf9c7cfe7cbf3dfed7",
var xmlPage = Resources["ContentLoaderFunctions"].LoadXML(prm);
// result: XML
var params = {
row.To = item.@to;
// row.Precipitation=(item.precipitation.@type+" "+item.precipitation.@value)==" "?"NoPrecipitation":item.precipitation.@type;
result.AddRow(row);
Thanks ,
Mayank
Hello Im have a diferent error mi code is
// Need to make a free wunderground.com account to get this key
var apiKey = "381603bc1002b5ce";
var temperature;
var humidity;
//Inputted location needs to be valid lat, long: 40.7127, 74.0059
if(location != null){
var test=location+" ";
var prm = {
// result: XML
var params = {
var row = new O
atbject();
row.To = item.@to;
result.AddRow(row);
attach image
Have you create a data shape for store value ?
