Problem on widget Three Model Viewer
dbologna1
1-Newbie
Hi All,
I'm using Thingworx 7.2.3 on VM Box Windows 7 64 bit.
I would to try a widget Three Model viewer.
I took a é.pvz file and i stored it into web area.
When I started the mashup it returned  the message "Unsupported file format pvz".
Where I'm wrong ?
Another question : when thingworx is on cloud machine (no access to the machine) where and how save the file that used by Three Model Viewer ?
BR
Dimitri
6 REPLIES 6
tschmitz
(To:dbologna1)
Hi Dimitri Bologna​,
I'm experiencing the same issue.  When browsing through the documentation associated with this extension,  there's no mention that pvs, ol, or pvz are supported, and when looking into the extension's zip, I don't see any variation of a pvz loader in the loaders folder.  Yet it certainly is showing up inside the widget as an option.
I suspect it's intended to work alongside the Creo View Extension found in the PTC Windchill Extension​.  I'd recommend contacting the author of the 3D Model Viewer ​(Select Author -> More about this author -> Contact this company) to see if this file extension should be supported on its own.
Tony
I am experiencing the same issue. Have you been able to solve it? And how?
Rami
tschmitz
(To:rmasoud1)
Hi Rami Masoud​,
I've followed up with the Thingworx Lab team, and will let you know what I hear back.
Tony
I am facing the same problem, have you found a solution ?
Hi there,
pvz is now supported.
Custom Repository Thingworx:
C:\ThingworxStorage\repository\FileRepository\<3DFilename.Format>
In 3D Model Viewer Widget
URL: http://localhost:8080/Thingworx/FileRepositories/FileRepository/<3DFilename>
ModelType: <Type> like pvz oder 3mf
Kind regards,
Erik Schmidt / inray Industriesoftware
slangley
23-Emerald II
(To:Erik25)
Hi @dbologna1.
If you are satisfied with one of the previous replies, please mark it as the Accepted Solution for the benefit of others who may have the same question.
--Sharon
