Hi All,
I'm using Thingworx 7.2.3 on VM Box Windows 7 64 bit.
I would to try a widget Three Model viewer.
I took a é.pvz file and i stored it into web area.
When I started the mashup it returned the message "Unsupported file format pvz".
Where I'm wrong ?
Another question : when thingworx is on cloud machine (no access to the machine) where and how save the file that used by Three Model Viewer ?
BR
Dimitri
Hi Dimitri Bologna,
I'm experiencing the same issue. When browsing through the documentation associated with this extension, there's no mention that pvs, ol, or pvz are supported, and when looking into the extension's zip, I don't see any variation of a pvz loader in the loaders folder. Yet it certainly is showing up inside the widget as an option.
I suspect it's intended to work alongside the Creo View Extension found in the PTC Windchill Extension. I'd recommend contacting the author of the 3D Model Viewer (Select Author -> More about this author -> Contact this company) to see if this file extension should be supported on its own.
Tony
I am experiencing the same issue. Have you been able to solve it? And how?
Rami
Hi Rami Masoud,
I've followed up with the Thingworx Lab team, and will let you know what I hear back.
Tony
I am facing the same problem, have you found a solution ?
Hi there,
pvz is now supported.
Custom Repository Thingworx:
C:\ThingworxStorage\repository\FileRepository\<3DFilename.Format>
In 3D Model Viewer Widget
URL: http://localhost:8080/Thingworx/FileRepositories/FileRepository/<3DFilename>
ModelType: <Type> like pvz oder 3mf
Kind regards,
Erik Schmidt / inray Industriesoftware
Hi @dbologna1.
If you are satisfied with one of the previous replies, please mark it as the Accepted Solution for the benefit of others who may have the same question.
Regards.
--Sharon
