We have had a major problems with upgrading ThingWorx version from version 7.3.8 to version of 8.4.3.
We tried the whole procedure on our TEST environment and had some problems.
What we have done:
delete from root_entity_collection where name = 'NotificationDefinitions';
delete from root_entity_collection where name = 'NotificationContents';
delete from root_entity_collection where name = 'StyleThemes';
Note: I dont like that I have to modify underlying DB by hand, Upgrade scripts should handle this (check if exists)
I had to repeat this step every time before ThingWorx fully loaded
Finally THingWorx started
So we have moved to PROD environment
Any suggestions when it comes to upgrading PROD environment with lot of data and extend business logic?
What would be the correct procedure.
Deactivating, stoping etc?
Would be better to do an incremental upgrade? I.e. from 7.3.8-7.4, 7.4-8.0, 8.1 - 8.2 etc..?
To keep the data safe, you may consider install a new PP, for example, you have pgSQL 9.5, you can install a 9.6 in the same or different environment, and share the same pgAdmin UI with different port number.
By doing this, you can easily roll back if migration didn't proceed well, and if it succeed, you can delete the old Database. (the upgrade of the PP is not reversible.)
You can always Use SQL command to export the data from PP directly, without going through composer. The data are always kept under same table name.
You don't need to separate the old data into 2 persistence provider now, additional persistence provider is a suggestion for your future operations. It gives you 2 cores, twice the storage space, and it can reconnect to a totally different server for data migration.
I would actually suggest you to install a new TWX 8.4 server, and then migrate all the data from old server to it, that would be much more efficient. Stop all the Timer and Scheduler during the process of course.
There has been so many changes between 7.4 to 8.4, licensing, composer, number of sql tables. Your concern maybe that the data inside Persistence Provider is very huge, and that would also lead you a way to improve the data structure and efficiency: Use additional Persistence Provider to hold Stream/Datatable/VS data, and store large amount of data in external JDBC.
Yes I was thinking about that as well.
Our problem is that we have about 300GB in DB (mostly streams).
We have tried to do export one time and it failed (during normal operation).
We had to export it stream by stream and in a case of big stream we had to do a partial exports.
We had problems even when importing model (entities) to new version of ThingWorx (dependencies are nightmare).
Questions:
Is there a way how to move data from DB to DB not involving composer?
If yes, is better to upgrade DB (model and data schemes) before we move the data?
If we decide now that we would like to split data (streams) into individual persistence providers can we initialize them with TW8.4 sql scripts if we have 7.3TW platform on tomcat?
How we move data from old DB to newly created PP?
Thanks a lot.
Is table scheme for data (VS, Streams, Datatables) still the same? I mean no differences between 7.3 and 8.4?
I will check it myself, but cannot hurt to ask.
We are using PG in HA mode, so we stopping the replication and using slave as backup.
Worked just fine. But still pain in the ass when it is not working.
In 8.4, 3 tables are called: data_table, Stream, Value_stream, so no big changes. And highly possible the columns also didn't change, only the number of tables varies.
Hi tcoufal.
If one of the previous responses allowed you to resolve your issue, please mark the appropriate one as the Accepted Solution for the benefit of others with the same issue.
Regards.
--Sharon
