I´m trying to upload a .CSV to Thingworx. I achieved it creating a service with CSV Parser, code:
var params = {
path: "/Tabla1.csv" /* STRING */,
columnMappings: "Temperature;Humidity;DateTime" /* STRING */,
hasHeader: true /* BOOLEAN */,
longitudeField: undefined /* NUMBER */,
dateFormat: "dd-mm-yy HH:mm:ss.sss" /* STRING */,
fileRepository: "DataLogger_1_Repository" /* THINGNAME */,
latitudeField: undefined /* NUMBER */,
fieldDelimiter: ";" /* STRING */,
stringDelimiter: "/" /* STRING */,
dataShape: "DataLogger_Shape" /* DATASHAPENAME */
// result: INFOTABLE
var result = Resources["CSVParserFunctions"].ReadCSVFile(params);
But now, I want send .CSV via REST API for instance with POSTMAN. I don´t know how I can do this. I put the URL (localhost:8080/Thingworx/Things/DataLogger_1_Repository/Services/), auth and headers but the body...
Could you help me with that?
Thank you in advance
BR
Hi Sharon,
Yes very helpfull, I saw that article and I solved it.
First I create a service with JSON input, INFOTABLE output and this code:
var par = {
path: params.path/* STRING */,
columnMappings: params.columnMappings /* STRING */,
hasHeader: params.hasHeader /* BOOLEAN */,
longitudeField: params.longitudeField /* NUMBER */,
dateFormat: params.dateFormat /* STRING */,
fileRepository: params.fileRepository /* THINGNAME */,
latitudeField: params.latitudeField /* NUMBER */,
fieldDelimiter: params.fieldDelimiter /* STRING */,
stringDelimiter: params.StringDelimiter /* STRING */,
dataShape: params.dataShape /* DATASHAPENAME */
var result= Resources["CSVParserFunctions"].ReadCSVFile(par);
me.Result= result;
Later I program a python code to send .CSV via REST API
while True:
DATA={
"params":
"path" : "/Tabla1.csv",
"columnMappings" : "Temperature;Humidity;DateTime",
"hasHeader" : 'true',
"longitudeField" : 1,
"dateFormat" : "dd-MM-yy HH:mm:ss.SSS",
"fileRepository" : "DataLogger_1_Repository",
"latitudeField" : 1,
"fieldDelimiter" : ";",
"stringDelimitir" : "/",
"dataShape" : "DataLogger_Shape"
r2=requests.post(url=URL, auth=AUTH, headers=HEADERS, json=DATA)
Thank you Sharon,
BR
Hi @ljam.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
