Jul 19, 2019 5:52 AM UTC
Design tab while creating Mashup is coming blank.
I can not see widgets in Design tab while creating mashup. Getting below error. Please see the below images.Capture1.PNGCapture.PNG
zyuan1Answer
Jul 23, 2019 7:05 AM UTC
You can compare with what you have now and check for the edits.
Support
Jul 19, 2019 1:15 PM UTC
Hi @manglapr.
Does the same behavior exist under the Administrator login?  Which version of ThingWorx are you running?
Regards.
--Sharon
manglapr1-VisitorAuthor
Jul 20, 2019 6:43 PM UTC
HI @slangley
I am using Administrator login only. Thingworx version is below as shown in image :-TW_Version.PNG
Support
Jul 31, 2019 6:13 PM UTC
Hi manglapr.
If one of the previous responses allowed you to find a solution to your problem, please mark the appropriate one as the Accepted Solution for the benefit of others with the same issue.
Regards.
--Sharon
