Hello All,
I am new user to the ThingWorx extensions and customization. I have created a new App for collecting incomplete workitems from Windchill. The requirement now, is to add this App to the list of default PTC Navigate Apps.
I tried to follow the below link, but there is some initial steps (extension setup / how to start the process of creating extensions).
Any help related to the procedure for adding newly developed App to the landing page is highly appreciated.
Thanks in advance for your help!
Hello, Srinivasa Kompella.
Are you using Navigate 1.3 as indicated by the link you reference or a later version?
Also, you may want to check out the Expert Sessions for ThingWorx Navigate at this location:
https://support.ptc.com/appserver/cs/portal/thingworx/csm.jsp?p=2
-- Craig A.
Hello Craig,
The Navigate is at version 1.3.0.
PS: I couldn't open the link you shared. May be, an access issue.
Can you please share a PDF or some other documents I can refer?
Hello, Srinivasa.
Let me confirm this with our Navigate team, but if I recall it may be Navigate version 1.5 or later is required to accomplish this.
-- Craig A.
