Proper application id for TWX Analytics Training Course - neuronuser or analytics works?
phughes
Trying to determine the proper user id for the Analytics Server for the Analytics Training course.  Using 7.4 Foundation and Analytics Server on the Developer Zone.  Tried neuronuser and analytics which both will work for the validation but when you go to the data section you get the following error and you can't successfully load the dataset.  Error invoking service: Wrapped org.apache.http.HttpException: { "naked-array": {"errorId":"fbc26c6f-605c-4fa3-a19d-91c179f8cf08","errorMessage":"No application found for id analytics"} } Cause: { "naked-array": {"errorId":"fbc26c6f-605c-4fa3-a19d-91c179f8cf08","errorMessage":"No application found for id analytics"} }
1 REPLY 1
phughes
(To:phughes)
Figured it out!
The password shown for the analytics server is the application id.  Enter whatever you want to for the application key as long as the key and the confirmation match.
This password is shown on the configuration pop-up box where you launch the Analytics Server.  Pop-up box is accessed via icon on the upper right hand side of the screen.
