Any one!!!
I am having usecase like mentioned below,
Thing 1:
Property 1
Property 2
Property 3
Thing 1:
Property 1
Property 2
I need to plot history data of Property 3 (Thing 1) and Property 2 (Thing 2).
Property selection may vary dynamically.
Is there any solution for this use case?
Thanks & Regards,
Sathishkumar C.
You can supply multiple data sources on a time series chart. Just de-select the box that says "SingleDataSource". Then you can choose the separate data for each data field.
This is okay. But my use case is selecting different number of properties from two thing. In future, Thing and properties count may increase.
Sathishkumar C.
