Uploading an image through REST api to an image property
  • November 29, 2017
  • 6 replies
  • 8186 views
Hello!
If I set up a property as an Image, how do I upload an image to that property using the REST api.
I have tried binary using Postman, I have tried base64, and several other. Usually I get 403 Request Forbidden response.
Application key is set. The problem is how to actually do the PUT request.
/Magnus
Best answer by posipova
You would need the following headers: content-type, Accept, appkey.
You would send the image as application/json
For example:
The image will be in json:
Hint: you may use your browser dev tools (Chrome - f12) to see the REST call structure when assigning an image property through the composer:
Scrolling down to the  request-payload, you can view the source:
posipova20-TurquoiseAnswer
20-Turquoise
November 29, 2017
For example:
måkerman1-VisitorAuthor
Hello Polina, and thank you!
I tried the exact way you explained and I got mixed result. The image do change in the property but I also get (500) Internal message response.
And the logging of the pimage property does not work even if the image is changed.
Do you know what it can mean?
20-Turquoise
November 30, 2017
Are you placing it as a PUT request? Is the appkey you are using connected to the Administrator user /has sufficient permissions? Are you passing it as json? I saw this error with a REST service request  rejected (HTTP 500 Internal Server Error) by the TW platform when a text value embedded in the JSON payload contains Line Feeds (ASCII 10),,, What is your ThingWorx platform version?
The problem was due to access rights. I used a different user to upload and that user did not have access to ThingworxPersistenceProvider.
I found the solution by reading this thread:
REST API property value update do not fire value change event
