Property History from different Thing - Plot in a single graph (Chart)
Sathishkumar_C
Hi All,
I am having  Thing 1 and Thing 2. Both the Thing having different properties.  I have to dynamically plot properties curve  from both the Thing in a same  graph (Chart). Is there any solution for this use case?
Sathishkumar C.
This document was generated from the following discussion:
3 REPLIES 3
Any one!!!
I am having usecase like mentioned below,
Thing 1:
     Property 1
     Property 2
     Property 3
Thing 1:
     Property 1
     Property 2
I need to plot history data of Property 3 (Thing 1) and Property 2 (Thing 2).
Property selection may vary dynamically.
Thanks & Regards,
Sathishkumar C.
You can supply multiple data sources on a time series chart.  Just de-select the box that says "SingleDataSource".  Then you can choose the separate data for each data field.
This is okay. But my use case is selecting different number of properties from two thing. In future, Thing and properties count may increase.
Sathishkumar C.
