Property values are repeating while using QueryPropertyHistory Service in ThingWorx
Aditya1702
Hello Everyone
Good Evening,
I am facing problem in logging properties there are some values which are repeating after I carry out the experience multiple times.
PFA attached image in which arrows are shown on the readings which are repeating when I consume the AR experience on my Ipad on view app for multiple times.
I just want to log the properties which are entered by the user on vuforia view app.
Below is the code I am using to write properties from Vuforia Studio to Thingworx:
I have written 2 services for pass & fail
Vuforia Studio JS Code:
$scope.SetStartStagePass = function (width) {
var TWXmodelID = 'Camera_UserStats_DT';
    var serviceName = 'GetSummary';
    var d = new Date();
    var parameters = { 'Emp' : $scope.app.params.empID, 'PartNumberInput' : $scope.app.params.partNo, 'Stage' : 'Step-' + j, 'StepValue' : 'Pass', 'DefectInput' : 'NA',
                      'StepImageInput' :  $scope.view.wdg['camera'].image};
    //console.log("Starting UPLOAD using image size " + width);
    twx.app.fn.triggerDataService('Camera_UserStats_DT', serviceName, parameters);
$scope.SetStartStageFail = function (width) {
    var d = new Date();
    var parameters = { 'Emp' : $scope.app.params.empID, 'PartNumberInput' : $scope.app.params.partNo, 'Stage' : 'Step-' + j, 'StepValue' : 'Fail', 'DefectInput' : $scope.app.params.defect,
Thanks in Advance.
30 REPLIES 30
Aditya1702
(To:vnamboodheri)
Hello Everyone,
@H_1234 , @Velkumar , @Rocko , @
Thank you for your support. I am using Datatable instead of Streams to store records into ThingWorx. Its working properly at present.
Best Regards,
Aditya Gupta..
