I am having an issue with the proportional chart, I am using it horizontally and set the chart max to be 100. All of my data sets go from 0 to 100 yet the grid shows up to 120 and the bars do not fill the entire chart. I have tried increasing my data set to go from 0 to 120 but the grid just shows 140. Has anyone run into this issue and found a resolution?
It seems as though the chart adds some extra space when the data is exactly the maximum. I was able to get it to be close by setting the y axis max to 100,000 and having my dataset go up to 99999.
