Hi All,
How usefull Search Expression in Search Data table Entries?
var params = {
maxItems: undefined /* NUMBER */,
searchExpression: undefined /* STRING */,
query: undefined /* QUERY */,
source: undefined /* STRING */,
tags: undefined /* TAGS */
// result: INFOTABLE
var rawdata = Things["En.KPIList"].SearchDataTableEntries(params );
How to use searchExpression Parameter??
Any Example??
Thanks & Regards,
Sathishkumar C.
Hello Sathishkumar,
"SearchExpression" can be used to create query for key values in Datatable.
For example:
You have DataTable with 5 key rows as
1. Room1Temperature1
2. Room2Temperature1
3. Room1Temperature2
4. Room1Temperature3
5 .Room2Temperature2
If you want only Room1 data, you can give search expression as "Room1*". It will result only Room1 rows.
PFA the PNG for operators used in SearchExpression
Velkumar R
Hello Sathishkumar,
For example:
Velkumar R
Thank You Vel kumar.
Thank you for yet aother partial answer that requires additional information seeking, which seems to be the standard on this website.
