QR Code Extension on Marketplace?
JanKerkhofs
7-Bedrock
I'm trying to integrate QR code create/read in our application and came across references in community forum to 'QR Code Extension' on PTC market place.
However, I am not able to find it there...
Is this extension not supported anymore? Perhaps available through other channels?
Thanks in advance!
For future reference:
I'm now using the public REST API calls of http://goqr.me/api/ to generate a QR image.
Using 'ContentLoaderFunctions - LoadImage' in a service (see below) returns a usable image (PNG).
Linking it to the 'Data' entry of a 'Value Display' inside a mashup allows for easy visibility.
Example (Input = string, result = Image):
var result = Resources.ContentLoaderFunctions.LoadImage({
6 REPLIES 6
tdixit
(To:JanKerkhofs)
Hello @JanKerkhofs
This extension is not supported anymore.
Toolika Dixit
Thanks for the quick reply!
Are there any other ways to generate/read QR codes using TWX?
slangley
(To:JanKerkhofs)
Hi @JanKerkhofs.
You would have to write your own extension for handling this functionality.  In the meantime, you can also post a request on the ThingWorx Ideas board.  This will allow other community members to vote for it in order to increase it's chances of being adopted into a future release of the product.
--Sharon
slangley
(To:JanKerkhofs)
Hi @JanKerkhofs
Thank you for sharing your solution with the community.  Please feel free to mark your last response as the Accepted Solution.
--Sharon
sagar.d
(To:JanKerkhofs)
If you find anything related to qr code extension from anywhere, please update, Than you.
