Query ValueStream with null entries
rwondoloski
1-Newbie
I get the following error when invoking a simple query on a value stream (using the DataFilter and TimeSelectors in the mashup).
[context: com.thingworx.webservices.context.HttpExecutionContext@71e1b30c][message: Unable to Invoke Service QueryPropertyHistory on N4A_Thing : null]
Is this because the field I am querying has null values?  The query is simply gps_status equals to 1.  There are lots of entries where this exists, but all I get is the error.
If I am not allowed to have null entries in the ValueStream, then how do I avoid this?  I need to filter out invalid location data when the GPS status is not valid.
1 ACCEPTED SOLUTION
billrei
6-Contributor
(To:rwondoloski)
Unfortunately, null in this case is probably the text description of the exception being thrown and not a reference to the values in your value stream. Could you try to make this call within a service to eliminate the possibility of a problem with your mashup bindings?
3 REPLIES 3
billrei
6-Contributor
(To:rwondoloski)
Bill,
Thanks for the response.
I try to test the query using a the built in QueryPropertyHistory, but get an error on my query syntax.  What is the correct syntax to perform the SELECT * WHERE gps_status = 1....This SQL type query gives an error about not following JSON query.  I am not familiar with, or can I find reference to JSON query....
Invalid QUERY value. Please make sure it's a valid JSON string
Thanks for the help!
Rob
qn
1-Newbie
1-Newbie
(To:rwondoloski)
What is your actual query ?
Based on the DOC 6.5 (http://support.ptc.com/cs/help/thingworx_hc/thingworx_6.5_hc/index.jspx?id=QueryParameterforQueryServices&action=show):
var query =
      filters:
          type: "EQ",
          fieldName: "gps_status",
          value: "1"
