Hey guys
I have a query that returns values to an infotable. I then want to query another table that contains the values returned in the first infotable using the "type" : "IN" filter, but I am not getting any results back. Can someone please push me in the right direction ?
The initial table query looks like this and returns 3 rows of values
var params = {
priority: Priority /* STRING */
// result: INFOTABLE dataShape: South32.Assign.Alerts.DataShape
var Alerts = Things["South32.HelperThing"].GetAlerts(params);
var DistinctParams = {
t: Alerts /* INFOTABLE */,
columns: "name" /* STRING */
var DistinctProbes = Resources["InfoTableFunctions"].Distinct(DistinctParams);
I now want to use these values as filter values on a subsequent query.
Are you creating a JSON array list of the values from the first Query to pass into the next query for the IN?
If you look here:
it shows the example of the IN
var jsonArray = [12,14];
var query = {
"filters": {
"type": "IN, NOTIN",
"fieldName": "Duration",
"values": jsonArray
