Hi
I have multiple things from a single thing template logging their properties on a valuestream . Is it possible to query the value stream to get the properties from different things, or should i use a data table instead?
Thank you in advance
Hi @GuiRosa ,
First, using the GetImplementingThings service of this template(generic template), so that you can get these things which use the template.
Then using OOTB QueryPropertyHistory or QueryNumberedPropertyHistory service to get these value stream parameters of each thingtemplate instance.
/Yoyo
When i use GetImplementingThings i get a table as a result.
QueryPropertyHistory is a method of a thing, i cannot pass directly the table that a got, so you're suggesting that i iterate the name column in a loop and call the queryPropertyHistory multiple times and maybe concatenate the result so i get one table?
If so, isn't better to use a shingle data table instead and all my things publishes their data in this single data table?
BR
Hi @GuiRosa.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
