Question about web socket feature in TW
tarik
I'm using the web socket feature in TW 7.3 (from Automatically update values when able checkbox), the feature worked only for one time and it didn't work after that at all,
I have the three error messages in the application  log as the following:
Message1:[context: com.thingworx.webservices.context.HttpExecutionContext@24f88415][message: Unable to Invoke Service GetClientApplicationKey on EntityServices : Import Failed: Unable to create applicationKey: [1,018] Data store unknown error: [Error occurred while accessing the model provider.]]
Message2:Unable to process import: Unable to create applicationKey: [1,018] Data store unknown error: [Error occurred while accessing the model provider.]
Message3:
[message: [1,018] Data store unknown error: [Error occurred while accessing the model provider.]]
Could you help me please identify the problem I'm facing.
Thanks in advance,
7 REPLIES 7
 You did binded any property of GetProperties result to a visual widget?
tarik
(To:CarlesColl)
yes, I did Carles, the button increase the counter and the getProperties is bounded to the label, after I click the button the label doesn't get updated
tarik
(To:tarik)
I noticed that I have 3 error message, I'll update the question
And DataChange event for Counter property it's thrown? I mean, which kind of Data Change Type it's defined for counter property?
tarik
(To:CarlesColl)
The Data Change Type is: Value
please also note the errors I have updated in the question
It maybe a permissioning problem as it says it was unable to create the Application Key, which it's necessary in order to "Push Properties" to work as described on the documentation: http://support.ptc.com/help/thingworx_hc/thingworx_7_hc/#page/ThingWorx_Help_Center%2FThingWorxHelpCenterDITAFiles%2FMashupBuilder%2FMashups%2FMashupAutoUpdate.html%23
Or, just thinking loud, you may have a different authentication system than the TW Standard one (Directory Services / Authenticators) and that's why the Application Key system doesn't works....
You can create Application Keys freely with the Composer?
tarik
(To:CarlesColl)
Hi Carles,
Sorry for being late, actually I can create new app key and this is the method I'm using for authentication.
