REST API not accepting credentials
afarley
1-Newbie
I'm trying to read and update property values using the REST API guide. I'm using Postman to test the following query:
GET [xxxxxx]/Thingworx/Things/HouseThing/Properties
I've specified my ThingWorx login credentials under HTTP Basic Auth parameters in Postman but the API is returning 401 Unauthorized. Am I supposed to have a different set of credentials for this authentication?
Updates:
I did have to create a new user (see the Users link on the left-side of the Composer window). Too bad this isn't mentioned under the REST API tutorial, or the Foundation tutorial, or the Quickstart tutorial. I couldn't see any indication from the API or the instructional documentation about the different types of ThingWorx credentials.
Now I'm having a different issue: when I run this query,
http://34.192.26.37/Thingworx/Things/HouseThing/Properties
I expect to see a list of the same properties that I see when I visit the "Properties" link under the HouseThing Composer view. In fact, I don't see *any* of the HouseThing parameters. The API response is as follows (why doesn't it show the address/temperature/light properties?):
<HTML>
    <HEAD>
        <TITLE>Property Listing For HouseThing</TITLE>
        <LINK rel='Stylesheet' href='/Thingworx/css/thingworxapi.css' type='text/css'></LINK>
        <META http-equiv='Content-Type' content='text/html'></META>
        <META http-equiv='cache-control' content='no-cache, no-store'></META>
        <META http-equiv='expires' content='-1'></META>
        <META http-equiv='pragma' content='no-cache, no-store'></META>
        <META http-equiv='refresh' content='30'></META>
    </HEAD>
    <BODY>
        <IMG SRC="/Thingworx/images/ThingworxLogo.png"/>
        <BR/>
        <H1>Property Listing For HouseThing</H1>
        <TABLE>
            <TR>
                <TH>name</TH>
                <TH>value</TH>
            </TR>
        </TABLE>
    </BODY>
</HTML>
1 ACCEPTED SOLUTION
posipova
20-Turquoise
(To:afarley)
Do you have necessary permissions set up on the user you are running the call from?
5 REPLIES 5
posipova
20-Turquoise
(To:afarley)
This was the issue. I had to go to "Security->Runtime" under HouseThing and add the newly created user. Thanks!
posipova
20-Turquoise
(To:afarley)
Awesome, thanks for the update!
When putting together REST calls with ThingWorx, the API will assume that data should be returned in HTML format unless you specify a different format using the "Accept" header.  For example, you can get the result back in JSON format by adding:
     Accept: application/json
To your Postman request.  This will return the results in a JSON object.   Similar can be done for XML:
     Accept: application/xml
Your response above does list the properties on the entity, just in HTML format.
It is a bit strange that you're not receiving any values.  Have you configured the properties as persistent and set a value?
Yep, they were configured as persistent and had a value set. The issue was user permissions. I am able to successfully get parameters in both HTML and json format now. Thanks!
