Hello everyone,
Currently I am working with Thingworx and Javascript. I am trying to do an API request from a SQL Query in Thingworx, having the following data:
Thing: Test WP
SQL (Query) Service: getTest
Service content:
Select * from public.countries
no inputs required
output infotable (i changed to json, but got an error, infotable is successfull)
Using Postman to try to test it:
GET [Thingworx_Server]Thingworx/Things/Test%20WP/Services/getTest
Params:
Accept=application/json
Content-Type=application/json
Headers:
appKey: Application Krey created on Thingworx
Using GET I got 405 response, if I change it to POST, I got:
Anyone knows how i can fix it?
I got "500 Internal Server Error"
Share more details about the error pls. Also see if you wrap it aroudn a JS service and that helps. That way you can also output JSON content easily.
Attach your Postman collection file, so that we can check it.
Hi @AR_10604442 ,
I wanted to let you know that there is an open question to you where you have posted a topic.
If you are in a position to respond to this question, that would be great. It can help you to receive an answer soon.
Abhi
