RHEL unable to start Tomcat.... class variable not specified
mnalla
7-Bedrock
Hi Guys,
I am installing thingworx8.0 on RHEL, I am unable to start tomcat, It is throwing the following error:
bash-4.2$ sudo systemctl status tomcat.service
* tomcat.service - Apache Tomcat Web Application Container
   Loaded: loaded (/usr/lib/systemd/system/tomcat.service; enabled; vendor preset: disabled)
   Active: failed (Result: exit-code) since Mon 2018-01-15 15:54:21 CET; 5min ago
  Process: 34298 ExecStart=/usr/share/tomcat8.5/8.5.13/bin/jsvc -Dcatalina.home=${CATALINA_HOME} -Dcatalina.base=${CATALINA_BASE} -Djava.awt.headless=true (code=exited, status=1/FAILURE)
Jan 15 15:54:21 mucxv347 systemd[1]: Starting Apache Tomcat Web Application Container...
Jan 15 15:54:21 mucxv347 jsvc[34298]: No class specified
Jan 15 15:54:21 mucxv347 jsvc[34298]: Cannot parse command line arguments
Jan 15 15:54:21 mucxv347 systemd[1]: tomcat.service: control process exited, code=exited status=1
Jan 15 15:54:21 mucxv347 systemd[1]: Failed to start Apache Tomcat Web Application Container.
Jan 15 15:54:21 mucxv347 systemd[1]: Unit tomcat.service entered failed state.
Jan 15 15:54:21 mucxv347 systemd[1]: tomcat.service failed.
Can you please help us.?
madhu
mgoel
(To:mnalla)
Hi Madhu Nalla
I believe you have already raised a Tech Support case for the same issue. Further assistance  would be provide on the same.
Mohit Goel
