Hello folks,
i have several questions about the Radio Button List in TWX 9.2.1.
Firstly, I would like to ask how I can create separator lines between the individual selection areas.
Furthermore, I don't understand how to address the Radio Button List with Custom CSS, for example to create a shadow.
Attached is an example of how the Radio Button List should look.
I am currently using this Custom CSS for the shadow, however it is not working.
Best regards
Here is some sample code that should add a horizontal separator and box shadow. radioCustomClass is the value of the CustomClass property for the buttonbar.
.radioCustomClass .widget-radiobuttonlist-wrapper{
box-shadow: 5px 5px 5px #888888;
.radioCustomClass .widget-radiobuttonlist tr:not(:first-child) td{
border-top-color: pink !important;
border-top-width: 5px !important;
border-top-style: solid !important;
Travis
/* Adjust size of radio button to big circle*/
.widget-ptcsradio::part(circle){
height:50px;
width:50px;
Reference - "ThingwWorx Web Components customization with Visual SDK CSS": https://www.ptc.com/en/support/article/CS324593
Hello Vladimir,
thank you very much for the quick reply.
Your described code refers to the Radio Button widget,
I needed help with the Type RadioButtonList. This is listed under Widgets as Button Bar Widget.
Best regards
Travis
