Radio button selected event should perform click event of service
svisveswaraiya
I am using an radio button with three strings and when i select a text i want to pass the selected text as input to three services and get output result and bind it to three label. But there is no click event available in radio button. In this case how can I trigger the service on selected item of radio button?
Pleas povide some help.
V Shalini.
4 REPLIES 4
For Selected Event you should look at your right side of mashup builder, there for the service that fills(binded) the RadioButton you have a Selected Row to get the Selected value on the Radio button.
I am not giving any data for radio button, its just the static names and I am able to get selected text but my requirement is on clicking a text I want to trigger an event without use of additional button. On click of one of text named ‘started’ in radio button i want to execute a service
You also have a Selected Row event on the right side (service) in order to trigger the other service that you want to trigger.
vi1
(To:svisveswaraiya)
You can use the Generic Radio button from Market place.See the attached screenshot.
Create the state definitions for Radio button states and map the states "ButtonStates"
You can bind the  "SelectedValue" property to text data for display the selected radio button text.
Map the "SelectionChanged" event  to service.
Thank You.
