Raspberry Pi Kit
minman1
Raspberry Pi Kit
Where do I get the files mentioned on this page?:
http://www.thingworx.com/developer/device-kits/raspberry-pi
10 REPLIES 10
I am also wondering the same thing. The guide references "twc_agent" installer files.
Aanjan
9-Granite
(To:minman1)
Mike, did you get the entire device kit? If so, can you give me more information on what was included in the kit?
I reached out to a PTC ThingWorx Consultant and discovered where to get these files.
On the Raspberry Pi page you linked, there is a "Quickstart Console" blue box on the left-hand side. In the box, there is a "Launch" button that prompts you to log in and download the zip file containing the install files.
Hope this helps.
I got the files as described under the "Launch" button on the side (only appears to work in Chrome, not IE), thanks!
So, next step… I have the files on my pi, I’m running twc_agent as described (sudo ./twc_agent) but I get a ton of ws_on_header_value: Websocket connection failed, twWs_Connect: Error trying to connect ws_on_header_value: Invalid ‘connection’ header: Upgrade messages.
When I ping device.cloud.thingworx.com, I get an IP address from DNS (54.208.223.221), but no response to the ping.
What needs to be upgraded here?
Aanjan
9-Granite
(To:minman1)
Mike, is the server you are trying to connect behind any proxy by any chance?
minman1
(To:Aanjan)
It’s behind a corporate firewall, but we don’t use a proxy to get out on http. Said another way, web browsing on the Pi that has the twc_agent installed is working fine.
Mike
minman1
(To:Aanjan)
Here’s the debug output from an attempted connection, it looks like the server wants to upgrade the client and the client doesn’t know what that means:
2015-10-29 16:05:59,735: twTlsClient_Reconnect: Re-establishing SSL context
2015-10-29 16:05:59,737: twTlsClient_Connect: Connecting to server
2015-10-29 16:05:59,787: twTlsClient_Connect: TLS connection established
2015-10-29 16:05:59,788: twWs_Connect: Connected to device.cloud.thingworx.com:80
2015-10-29 16:05:59,788: twWs_Connect: Sent request:
GET /Thingworx/WS HTTP/1.1
User-Agent: ThingWorx C SDK
Upgrade: websocket
Connection: Upgrade
Host: device.cloud.thingworx.com
Sec-WebSocket-Version: 13
Sec-WebSocket-Key: JZNA7gcNtfUhfDqn8pLwZQ==
Max-Frame-Size: 8192
applicationKey: 2fbdab1f-4cd6-43df-8d3f-6e3c18a2d5a2
2015-10-29 16:05:59,967: HTTP Response begun
2015-10-29 16:05:59,967: Header->server : Apache-Coyote/1.1
2015-10-29 16:05:59,967: Header->upgrade : websocket
2015-10-29 16:05:59,967: Header->sec-websocket-accept : cVyWkGmJ2JxlY9vpR2i9bxFoAtQ=
2015-10-29 16:05:59,967: Header->date : Thu, 29 Oct 2015 20:06:04 GMT
2015-10-29 16:05:59,967: Header->connection : Upgrade
2015-10-29 16:05:59,967: ws_on_header_value: Invalid 'connection' header: Upgrade
2015-10-29 16:05:59,967: ws_on_headers_complete: Websocket connection failed
2015-10-29 16:05:59,967: twWs_Connect: Parsed 193 bytes out of 193
2015-10-29 16:05:59,967: twWs_Connect: Error trying to connect
2015-10-29 16:05:59,967: twTlsClient_Reconnect: Re-establishing SSL context
2015-10-29 16:05:59,969: twTlsClient_Connect: Connecting to server
2015-10-29 16:06:00,22: twTlsClient_Connect: TLS connection established
Aanjan
9-Granite
(To:minman1)
The reason I asked about the proxy (especially reverse proxy) is because the connection headers are case-sensitive. The header sent there is 'Upgrade', while the agent/ sdk is likely expecting 'upgrade'.
mr1
(To:minman1)
Mike, I am behind a DSL modem at home trying to connect with Pi. I am also getting the same error. Were you able to make it work?.
