Jun 3, 2021 3:43 PM UTC
[Raspberry pi 3+ ]WS EMS SSL connection and self-signed certficate
hi all
im strugling tring to connect with SSL my raspyberry pi 3+. Without SSL i didn't face with errors but actually i get always the following error:
root@raspberrypi:/home/pi/Downloads/microserver# ./wsems
[FORCE] 2021-06-03 15:33:23,883 ./wsems: Initializing EMS ....
[FORCE] 2021-06-03 15:33:23,883 main: Using config file /home/pi/Downloads/microserver/etc/config.json
[INFO ] 2021-06-03 15:33:23,883 ./wsems: Creating the WsEms proxy.
[DEBUG] 2021-06-03 15:33:23,883 DutyCycle::calculateDutyCycleTimePeriods: m_ConnectPeriod: 60000
[DEBUG] 2021-06-03 15:33:23,883 DutyCycle::calculateDutyCycleTimePeriods: m_DisconnectPeriod: 0
[INFO ] 2021-06-03 15:33:23,883 ./wsems: Starting HTTP Server.
[WARN ] 2021-06-03 15:33:23,883 Main: Encryption is disabled on HTTP Server.
[WARN ] 2021-06-03 15:33:23,884 Main: TLS Hostname Validation Is Disabled
[WARN ] 2021-06-03 15:33:23,884 Main: Authentication is disabled on the HTTP Server.
[INFO ] 2021-06-03 15:33:23,884 ./wsems: Initializing the ThingWorx REST interface.
[FORCE] 2021-06-03 15:33:23,884 httpServer: starting http server port=9000
[INFO ] 2021-06-03 15:33:23,884 wsEmsProxy::initialize: FIPS is disabled.
[INFO ] 2021-06-03 15:33:23,885 wsEmsProxy::initialize: Encryption is enabled on Web Socket connection.
[DEBUG] 2021-06-03 15:33:23,885 wsEmsProxy::initialize: EMS Duty Cycle configuration from config.json:
[DEBUG] 2021-06-03 15:33:23,885 wsEmsProxy::initialize: m_DutyCycle.setDutyCyclePeriod: 60000
[DEBUG] 2021-06-03 15:33:23,885 wsEmsProxy::initialize: m_DutyCycle.setDutyCyclePercent: 100
[DEBUG] 2021-06-03 15:33:23,886 wsEmsProxy::initialize: m_DutyCycle.setConnectTimeout: 10000
[DEBUG] 2021-06-03 15:33:23,886 wsEmsProxy::initialize: m_DutyCycle.setConnectRetries: -1
[DEBUG] 2021-06-03 15:33:23,886 wsEmsProxy::initialize: m_DutyCycle.setDelayDutyCycle: 60000
[DEBUG] 2021-06-03 15:33:23,886 jsonConfigurator::getJsonEntity: Key fingerprint_whitelist not found
[WARN ] 2021-06-03 17:33:23,886 SDK: SDK Version: 2.2.11
[WARN ] 2021-06-03 17:33:23,887 SDK: TLS Library: OpenSSL
[WARN ] 2021-06-03 17:33:23,887 SDK: TLS Library Version: 1.1.1c
[DEBUG] 2021-06-03 17:33:23,887 SDK: twWs_Create: Initializing Websocket Client for 10.0.0.4:443/Thingworx/WS
[DEBUG] 2021-06-03 17:33:23,887 SDK: twTlsClient_Create: Initializing TLS Client
[DEBUG] 2021-06-03 15:33:23,888 httpServer: http server bound to port=9000.
[DEBUG] 2021-06-03 17:33:23,900 SDK: twApi_Initialize: Websocket Established after 0 tries
[DEBUG] 2021-06-03 17:33:23,900 SDK: subscribedPropsMgr_Initialize: Initializing subscribed properties manager
[INFO ] 2021-06-03 15:33:23,900 WsProxy::initialize: EMS Version 5.4.9.1154
[INFO ] 2021-06-03 15:33:23,900 WsProxy::initialize: twApi singleton initialized
[WARN ] 2021-06-03 15:33:23,900 WsProxy::initialize: Certificate validation is disabled.
[DEBUG] 2021-06-03 15:33:23,900 jsonConfigurator::getJsonEntity: Key validation_criteria not found
[DEBUG] 2021-06-03 17:33:23,901 SDK: twTunnelManager_Create: Tunnel Manager singleton already exists
[DEBUG] 2021-06-03 17:33:23,902 SDK: added PeppeRaspberryTest to boundList
[DEBUG] 2021-06-03 17:33:23,902 SDK: twApi_BindThings: not currently connected, only binding things to api
[DEBUG] 2021-06-03 17:33:23,902 SDK: twMessage_Delete: Deleting BIND Message: 1
[INFO ] 2021-06-03 15:33:23,902 WsEmsProxy::registerVirtualDirs: Adding virtual dir in: /home/pi/downloads/in
[INFO ] 2021-06-03 15:33:23,903 WsEmsProxy::registerVirtualDirs: Adding virtual dir out: /home/pi/downloads/out
[INFO ] 2021-06-03 15:33:23,903 wsEmsProxy::initialize: Initialization complete!
[INFO ] 2021-06-03 15:33:23,904 ./wsems: Starting the connection.
10.0.0.4:443-->[DEBUG] 2021-06-03 17:33:31,918 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2021-06-03 17:33:31,919 SDK: twTlsClient_ConnectSession: Connecting to server
[ERROR] 2021-06-03 17:34:02,77 SDK: twTlsClient_ConnectSession: Error initializing socket connection. Err = 115
[ERROR] 2021-06-03 17:34:02,77 SDK: twWs_Connect: Error restarting socket. Error 115
[DEBUG] 2021-06-03 17:34:07,78 SDK: twTlsClient_Reconnect: Re-establishing SSL context
[DEBUG] 2021-06-03 17:34:07,78 SDK: twSocket_Close: socket is already closed or was never opened
[DEBUG] 2021-06-03 17:34:07,78 SDK: twTlsClient_ConnectSession: Connecting to server
^C
i've uploaded my files:
- config.lua
- config.json
- template
slangleyAnswer
Support
Jun 9, 2021 7:24 PM UTC
Hi @GF_9594158
From a review of the files you provided, it doesn't appear you have configured your certificate.  Since you're trying to use a self-signed certificate, the config.json also needs to be updated to allow self-signed certificates.  Here's an article that may help.
Is ThingWorx running SSL?
--Sharon
slangleyCommunity ManagerAnswer
Support
Hi @GF_9594158
--Sharon
Jun 21, 2021 9:23 AM UTC
I fixed it.. thank u
