Hi Carles,
Thanks! How should the JSON inputs be formatted? Is there any documentation available for that?
For example, I am trying to use SearchThings and use the ThingTemplate filter.
Best regards Erik
Related to previous post
Hello Erik,
For instance if you want to recover System Users you can use "aspects" parameter do as follows:
var result = Resources["SearchFunctions"].SearchPeople({
maxItems: undefined /* NUMBER */,
searchExpression: undefined,//"wup*",
modelTags: undefined /* TAGS */,
query: undefined /* QUERY */,
aspects: { isSystemObject: true },
excludedAspects: undefined /* JSON */,
maxSearchItems: undefined /* NUMBER */
}).peopleResults;
That's the only that I know and I've used.
aspects -> Aspects to match
excludeAspects -> Aspects to exclude? doesn't seem to be the inverse of aspects...
If you look at DataShape SpotlightSearch you have more fields that seems aspects, but I didn't tried it:
Carles.
Hello Erik,
}).peopleResults;
Carles.
Hope you are doing good. Could you please confirm if the issue has been resolved.
If yes, please mark @CarlesColl answer as accept as solution for the future reference. Thank you in advance.
Regards-Mohit Goel
