I am facing the same problem while configuring the MS SQL server with Thingworx.
Some one posted the below link but when I click on this - I see insufficient privileges message.
I am trying to configure MS SQL server to thingworx. As per the installation guide it says
" Obtain the database setup script (thingworxMssqlDBSetup.bat) from the ThingWorx software download."
But in the download folder I don't see this file. Can you guide me in getting the required file.
RM
Message was edited by: Sushant Pandey branched from https://community.thingworx.com/message/63974
Hi Rashmita, what version of ThingWorx are you working with? All the scripts are under install/update folder, here's screenshot from install folder
