Read CSV starting on a different row
fguerra
I'm using the Read CSV Snippet to read a csv file from my repository but this file has some lines at the beginning before starting with the information I want to show as infotable.
Is there any way to skip those likes without modifying the csv?
The csv file looks like this:
# Solar panel simulation inputs 2 of 2
# P9 - T_ambient, P27 - WB_Voc, P26 - Isc, P13 - WB_Panel_fill_factor
Name,P9,P27,P26,P13
1,20,6.1,0.00018,0.6
I want to show the infotable with the info starting on Name,P9…  but since the file probably will change from time to time I don’t want to change the format or the content.
Any help would be appreciated.
Felix
2 REPLIES 2
Hi Felix,
You need to remove that rows on the file itself and rewrite it before parsing it through CSV extension, I do it that way:
var fileRepository = Things["file repository thing"];
var fileContent = fileRepository.LoadText({ path: "path to your file" });
var rows = fileContent.split("\n");
// -- Starting at 7 rows are the good ones.
var newContent = [];
for (var i=7;i<rows.length;i++) {
    newContent.push(rows);
fileRepository.SaveText({
    path: path,
    content: newContent.join("\n")
Hope it helps,
Carles
fguerra
(To:CarlesColl)
Hola Carles,
Thank you for your answer, great idea, I will test it.
Regards
Felix
