We would have a paper label with barcode which will have order number. The requirement is to scan the barcode in the paper and populate the content in text box in ThingWorx. How can we achieve this functionality in ThingWorx 9.1?
If you use a 'bar code to text input' setup. Then all you would do is, click in the field to be populated and then scan the bar code.
